sliding glass door not level
Old 06-30-08, 09:18 AM
H
Herculite brand name sliding glass door not sealing up on closing side. Removed door, and do not see how to adjust wheels. Screws at bottom of door are for wheel removal. Any help would be most appreciated, cause a lot of the a/c is leaking out.
Old 06-30-08, 03:42 PM
Not familiar with that brand, but look again. The screws for adjusting are either in the end of the door or on the side, behind cover plugs. They will raise/lower one side to square the door with the jamb. Usually both bottom ends have adjusting screws, and there may be tensioning screws for rollers at the top.
Old 06-30-08, 06:14 PM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Everything I saw on this was referencing commercial doors? The adjustments would be different if thats the case.
Old 07-02-08, 08:36 AM
H
Naw, the screws are tight, both sides. I can remove the door pretty easily, and it doesn't look like there are springs on the rollers. Home Depot told me to bring the rollers in for them to look at for replacement. But the rollers are fine, just the door is not plumb.
