Replacing Garage door with sliding glass door
I have removed my garage door so I can install a sliding glass door. Naturally directions a vague. I'm not sure how to install the lower end of door frame.
Any suggestions on how to secure the bottom frame to a concrete slab?
Do I need to use pressure treated lumber for the bottom of the frame?
Can I use liquid nails to secure the bottom of the frame to the concrete?
Any info will be greatly appreciated
Bill
Bill
I'm guessing that you're planning on having a short piece of sill plate on either side of the door. Yes, it should be treated... yes you could use liquid nails... but I'd also recommend that you put a pair of tapcon cement screws in it. 1/4 x 2 3/4 would work well. You drill the hole with a hammer drill, then put the screw in.
