Mobile home window project !
Old 07-20-08, 08:16 AM
0
First off great forum ! I have a quick question . My mother needs new windows in her 80's mobile home. My question is what type of window, meaning new construction or replacement works best . The old windows are the aluminum type that screw in from the outside. They are pretty shot and real drafty in the winter. Thanks !
Old 07-20-08, 08:23 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
You may not be able to find N/C windows in the sizes you need. If you can, they would probably be the better choice, as you can get extension jambs applied that will bring it flush to the interior wall.
Replacement windows can be custom sized to the opening and some types can have nailing fins applied. You would need to do some trim work more than likely to finish off the interior.
You need the actual hole size you will be putting them in and the thickness of the walls, then visit a few local distributers of diff types/brands to see whats available.
Old 07-20-08, 08:31 AM
0
With the replacement windows i would have to also trim out the outside of the window also right ? I just knew that the n/c window they screw in from the outside and i wouldn't have to trim out the outside just the inside.
Old 07-20-08, 09:42 AM
Gunguy45's Avatar
Super Moderator
Well,
Again, it depends on the window brand.
The repl windows that can have a nailing fin applied would look just like new construction w/o the jamb on the inside. The fin fits into a groove on the sides, top and bottom. (There would be an overlap of the fins at each corner, where a N/C would have a continuous fin all around.) That would need to be caulked at the groove where they attach. Even had a guy who used pvc cement on the back to make it permanent. Don't think I'd go that way. You still might want to trim out the exterior, and use a membrane type wrap around the opening under the fin.
I still think the issue will be if you can find the right size in a N/C window. Unless the existing windows are standard sizes (not likely in a 30 y/o moble home) you would have to modify the opening.
There are other guys on here, who are way more knowlegable about windows than I am. I sold some brands and did a few installs over 5 yrs. Even helped a guy do some work on his mobile home (front door and some windows), so I have an idea of what you may run into, but not an expert by any means.
Old 07-20-08, 12:59 PM
Received 754 Upvotes on 659 Posts
The majority of MH windows are nothing more than storm windows - some will have 2 sets, 1 interior and 1 on the exterior. If you have the awning type MH windows, replacing them with the storm window type [single hung] would be a big improvement. The size needed might be available thru a MH supply center.
While replacing the windows with regular insulated windows would be best it will also be the most work. Even if you can find the exact size [doubtfull] you would have to devise flashing to keep it from leaking. Does this MH have the standard aluminum sheet siding with a metal roof?
Whenever I've changed out MH windows to conventional type windows it has been part of a remodel project which usually involved reframing the opening and often a change in siding and roofing.
btw - welcome to the forums!
Old 07-20-08, 04:54 PM
0
Thanks guys for the help !
This m/h has the metal siding , i believe its an 89 model.
It has the windows like you described, with the in side storm window for the winter. Do you think that if we went with a s/h window that a inside storm window would still be needed to keep out the cold ? Mom wants a double hung tilt style window to make it easier to clean ect.
Thanks again for the help/answers !
Old 07-21-08, 03:47 AM
A conventional insulated double hung window installed correctly will be the most efficent, just not the easiest to install. Framing the opening to accomadate the window is the easy part - the trick is the flashing! Caulking will seal it for a little while but without flashing, sooner or later water will enter the wall cavity causing damage
