Screen door rough opening size?
Old 07-25-08, 05:50 AM
D
Received 1 Upvote on 1 Post
I'm in the process of framing in my patio to make a screen porch. I've purchased a 36" screen door (net 35.75 X 80.75). What size rough opening will I need for this door? Thanks.
Old 07-25-08, 06:50 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
The box or instructions should have the min and max openings that it can be adjusted to fit.
I'd make it right at 36" x 80 1/2". Same as the brickmold opening on a std ext door. You will have plenty of adjustment, bout 3/8" side to side and 1/2" at the bottom. Just make sure its square, plumb and level. And you may want to consider putting a small slightly raised aluminum threshhold in the opening. May help with sealing at the bottom.
Old 07-28-08, 10:25 AM
D
Thanks for the info....
The 36" width worked fine, but I used 81.5" for the height because the door was 80.75 high, so the 80.5 was short. The door fits and looks great.
