Screen Door Handle
Old 07-28-08, 09:26 AM
Screen Door Handle
When facing my backyard door, the door handle is on the left side. I purchased an Anderson screen door for my backyard door and when we put it up it seems that the screen door I bought is meant to open from the right side. So we turned the screen door the other way and installed it but you have to pull up when opening the screen door instead of pulling down. It makes it very confusing for guests. Is there something that I did wrong or is there a way to fix it so I can keep the handle on the left side and be able to pull down to open it?
Old 07-28-08, 10:04 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Bet yer deadbolt is on the top too, depending on the model you have.
Btw which model do you have?...there are other quirks on some of them also.
Look in the lock instructions. You need to reverse the bolt in the lock mechanism.handle. IIRC, basically you take out 2 screws and a cover, pull the bolt out, turn it over and put it back together.
Ahh...found it... heres the answer from Andersens site.
http://www.allseasonsdoors.com/faq/i...d=113&cat_id=3
Old 07-28-08, 07:26 PM
I got it to work. Thank you!
