Sliding glass door issues...
Old 07-29-08, 02:30 PM
Well it appears that my weep holes have been a bit clogged with animal hair which casued water damage inside the house. This is being repaired. My question what is the best way to remove the hair inside the weep channel?
My second question....
There is a seal that sits on the piece of the door that holds the stationary door closed but rests against the bottom of the opening door. I can pull this seal out and it is worn in some places. What is this seal called and is it possible to replace this? It is torn in some areas.
Old 07-29-08, 02:53 PM
Here is a better example of my second question with pictures....first is the whole piece and wonder if it is removable to replace (no clue who the manufacturer is, was turnkey), and the second question about that rubber seal (which I can remove), is it possible to replace?
