Door Gaps
Old 10-01-08, 11:35 PM
B
Door Gaps
I Have A Double Exterior Stanley Door And A Gap Has Developed In The Center Of The Door Letting In Drafts And Also You Can See Daylight Through The Gap How Can This Be Repaired
Old 10-02-08, 04:52 AM
Need more info, wood, fiberglass, etc??? Is this something recent?? It sounds like the door has warped and there is not much that can be done to correct that. Resetting weatherstripping may be a stop gap, but it likely needs a new door slab. Stanley has been bought out by Masonite, but there may still be a warranty on the door(usually 10 yrs).
Old 10-02-08, 07:53 AM
K
In addition to the questions Bill asked can you tell us if there is any play in the door? By that I mean can you take the door and shake it or is it firmly attached to the wall? Are the hinges loose? Does the door jamb itself move when you open and close the doors, or even if you push on the jamb itself?
Jim
