Closet Openings too small
Received 0 Votes
Hi everyone,
In our home the previous owner changed the closet sizes and in doing so changed the opening sizes. They never added doors to the closets either. I have already installed new 6 panel pine doors throughout the house and was looking to add the same pine bi-fold doors to the closets. I was also hoping to install jambs first. I am concerned that I may not be able to based on the opening sizes that are currently there.
In bedroom 1 the closet opening is 72" on the nose. In bedroom 2 the opening is 71 1/4'. And in BR 3 the opening is exactly 48". I assume that because of that I can't install a jamb and in the case of BR2 I cant expect to fit the bi-fold doors at all.
Do I have no choice but to install sliding closet doors?
Thanks in advance,
Ken
Thanks in advance,
Ken
Received 0 Votes
Bypass(sliding) door openings are usually about an inch smaller the bifold door openings, to allow door overlap. Thus, it is usually harder to fit bifold doors into a bypass opening without major trimming on the doors. Byfolds should easily fit the 72" & 48" opening, but may need trimming for the 71" opening. You could also install the doors on hinges.
