HELP !--- enlarging a window
we have a window in our ding room and its 32 x 50, we want it to be 36 x 52 or 36 x 54 . we were told it would cost us 500 bucks for labor and material(not counting the window). they said something about needing another header because we are going wider? what is a header? what is it made of and what is it for?
thank you guys
thank you guys
The header is the framing above the window that supports the structure above the window, and expanding a window opening can be expensive. Yes, the opening does need a new header, after tearing out the existing framing and wall covering inside/out.
Taser - I think $500 labor and material is probably a bargain. In addition to the window, they will have to provide flashing, trim, a new header and framiing lumber. Depending on the type of header they use, materials may cost $100 or more.
