Will this work
Will this work
We are in the process of having Marvin Infinity double hung windows installed on the lower level of our walkout rambler. One of the windows is on the brick portion of our home. The window didn’t fit the opening, so the company’s installers removed the end cap and cut the window aluminum face by about a 1/8 on both sides. The end cap piece was not replaced. The cutting chipped some of the factory-applied finish, which is now covered with caulk.
My questions are:
1. Have any of you pros done this, and is this a common practice? We were told it is done in at least 5% of their jobs.
2. Will this affect the integrity, functionality and service life of the window? We were told that it will not.
3. Since installation is a factor that Marvin considers in its warranty policy, will this affect the warranty? We requested that the company get a letter from Marvin and co-signed by themselves that the warranty will be honored.
The cut window is now installed. The company said that if we are not satisfied with the window, they will order and install a new one made to fit the opening. Would you do this?
There has been not been any discussion of a price adjustment if we stay with the window they cut and installed. If we accepted this window, what percentage reduction would you recommend we demand?
Thanks in advance for the help.
My questions are:
I would be surprised if Marvin will warrant that window. Have them install a new one at their cost. The unit could be fine the way they installed it but I would not take the chance. There should be no charge to you.
Thanks Bill62
We have decided to ask for a new window.
A neighbor is the owner of a large commercial construction company who often uses this company. He said he had never seen a window cut. He is going to talk to the owner.
Last edited by Shadeladie; 11-04-08 at 10:58 AM. Reason: Removed unwarranted remark
Marvin is a top quality window and the price reflect it, so they should make this right. Although it the installer, not Marvin that is responsible. Yes, it should be done correctly. My guess is someone mis-measured that window.
Just curious. Who measured for the window? Did you order thru Marvin or someone else?
What company are you talking about?
