interior door size???
Old 10-27-08, 06:34 PM
R
I am getting ready to frame in a pocket door for the master bath. What is a good size door for this opening? I have bought a pocket door frame that is 30 inches, but to keep from crouding the shower, I would like to use a 24 inch or a 28 inch door. Would this make the opening seem to small?
Old 10-27-08, 10:52 PM
2
You'll probably reget using a door less than 30” wide, although it's your choice. In space saving situations I have seen many plan sets from reputable architects spec pocket doors 28” wide. If you want a narrower door climb in the back of a camper & try one out, before jumping into the frying pan.
Old 10-28-08, 04:12 AM
I would use nothing smaller than 28". But have you checked to see what is in the wall where the door will go, assuming it is not now a pocket door. Installing a new pocket door requires tearing out the wall and installing a new header above, in most cases. There is often wiring that needs to relocated, possibly heating and plumbing. There are things like sewer mains, and plumbing that is hard/expensive to relocate that make a project like this unreasonable.
Old 10-28-08, 09:47 AM
Received 786 Upvotes on 689 Posts
Back in the day, I painted a lot of 24" bath room doors [pocket and hinged] but I wouldn't recomend using one that narrow. IMO 30" is the perfect size unless you need to make it wheel chair accesible. Of course sometimes you have to go with what fits.
Old 10-28-08, 07:38 PM
R
Thanks for the help! I have completly removed the wall, and yes it was a 2 by 6 "wet" wall that had a 3 inch sewer vent stack, water supply lines and the wiring for the switches. But that is all laying aside until I decide on the door size, a 30 inch door will fit in that after walking thru the door [12 inches into the room] there will be the edge of the shower -four inches is in the 30 inch space. But I do agree in that a 30 inch door will be better in the long run for ease.
