engineered flooring in a condo
hello, im putting engineered hardwood floor in a condo, and would like to know how most of you would deal with the steel door frames?
would you cut the bottom of the frames so that you can slip the flooring under the frame? if so what tool do you use, a steel bladed reciprocating saw , or a cutoff wheel on a drill?
