Oops! I cut the wrong end of my wood door.
Old 01-03-09, 09:54 AM
G
I needed to cut about a 1/4" off bottom end of a 6 panel wood door so that the door would close properly, but instead I carelessly cut the top of the door . I'd like to reposition the hinges a 1/4" down so I don't have to buy a new door. But, I think the new holes will be too close to the old holes. What's the best way to handle the old holes so that I can create new holes very close by?
Thanks,
Guy
Old 01-03-09, 09:57 AM
W
Received 20 Votes on 19 Posts
Door
Fill the holes with glue and golf tees. Let dry thoroughly. Then re-mortise the door to move the hinges.
Old 01-03-09, 10:51 AM
2
The crossbore and latch bore will not aline with the strike after repositioning the hinges. Everything must be altered.
Old 01-03-09, 11:37 AM
G
Thanks for the replies.
OK, so any thoughts about whether it is better to raise the jamb-side hinge or the door-side?
Old 01-03-09, 02:02 PM
badeyeben's Avatar
Why not just add quarter round above the door to cover that gap?
Add it to the door frame top over the doorstop.
Old 01-03-09, 04:52 PM
chandler's Avatar
Received 6 Votes on 6 Posts
If the door framing is removable, you can rebuild the jamb set to where everything is lifted . I would opt for that, again, if it is removable. Only requires a couple of cuts and nail it back together. Looks better on the hinge side and you don't have to adjust the striker, either.
