replacing doors
replacing doors
Getting rid of hollowcore slab doors with 6 panel doors. Home Depot just went to $19 per door. $34 per door for holes and notches put in them - I believe I can handle the holes and notches for $15 X 9 doors!!!
Glad I hadn't put them up already - thunder makes our dog really nervous - - -
Yep, I got nerve pills for the dog now!!
bamakodaker
bamakodaker
The holes for the doorknobs and the mortises for their latches are very easy and very forgiging if you get them off a 1/16" or so. That's not the case with the mortises for the hinges. The hinge has to seat fully in the mortise with no wiggle room top or bottom. When I replaced about 10 or 12 I made a jig so my router was cutting each mortise precisely. After that, it's just very care and extemely accurate measuring involved.
Hey lefty...not fair answering questions that weren't asked...lol
Bama...if you plan on using a router..they sell inexpensive jigs for the hinges that will work just fine.
Lefty is right...measure the hinge mortices very carefully. Measure 3 times (in this case) rout once...
