Anderson Window Repair (spring)
Old 04-23-09, 08:23 AM
Hello,
I have 18 year old, Anderson double hung (builder grade) windows in my house. The other day, as I was closing one of them it sounded like a spring broke inside the window/frame. Now the window is extremely difficult to close.
any idea what broke and can it be repaired? how difficult of a job will be be?
the other windows all work and are holding up pretty well.
Thanks!!
Scott
Old 04-23-09, 03:22 PM
C
You might check with Anderson. If a slider spring or such broke, it should be replaceable. Finding the part and disassembling the window would be the challenges.
Old 04-23-09, 03:43 PM
There is a triangle etched in the corner of the glass with the Andersen logo and some numbers/letters. Give that and the glass size to Andersen, they can supply the correct balance. It is usually the cable that breaks(nylon), and it should come with instructions.
Old 04-23-09, 03:48 PM
johnam's Avatar
Received 12 Upvotes on 11 Posts
Bill just beat me to it but this link will show you what you'll be up against to replace the balance.
http://www.andersenwindows.com/servl...&ssbinary=true
Old 04-24-09, 06:09 AM
thank you everyone.. i'll look into it in more detail this weekend and post my results..
Scott
