How to Determine Manufacturer
Old 05-07-09, 10:01 AM
D
How do I determine the manufacturer of a door? I have looked all over the door, except for the bottom, and I don't see anything that would indicate the manufacturer. It is a metal exterior kitchen entry door.
Old 05-07-09, 10:13 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Some brands may have a stamp, label, or impression under one of the hinge leafs. Normally but not always, the middle leaf on the door side.
Old 05-07-09, 10:16 AM
D
thank you - I'll have a look.
What about a sliding patio door?
Old 05-07-09, 10:39 AM
Gunguy45's Avatar
Super Moderator
Those can be pretty tough. Even good quality sliders can be hard to figure out. Almost everyone I've seen (before it was installed) had labels..but they were all on the BACK of the frame, not visible once installed.
Why do you need to know btw? Most cheaper doors use generic parts and hardware.
Old 05-07-09, 10:43 AM
D
I had the kitchen door and sliding door installed about 10-11 years ago. I've lost the paperwork. They were expensive ($3K at the time). The sweep of the kitchen door is now tearing, and will need to be repaired.
Old 05-07-09, 10:56 AM
Gunguy45's Avatar
Super Moderator
Most door sweeps use limited styles. Some slide into a track, some fit into grooves on the bottom of the door and are stapled in place. Once you take it out, you should be able to go to a good local hardware store and they will be able to find a replacement.
There can be a few that are hard to find, since they may have changed styles or been bought out. If you have a problem locally, come back here and post a pic of the sweep, someone will have an answer.
Old 05-07-09, 11:38 AM
D
I looked under the middle hinge of the kitchen door. This is what it had:
210544-1 SCH 117 13/98
Item # 160-NC 6P EMB SLAB 3068 NB
?HIS NC S? 3068 MARY
?51/SM 24
The "?" are where I couldn't make it out.
Do any of these numbers indicate the manufacturer?
Old 05-07-09, 11:58 AM
Gunguy45's Avatar
Super Moderator
Well, I can decipher some of it...but not the maker..sorry..
210544-1 SCH 117 13/98 -prob a spec and manufacture date (13th wk of 98)
Item # 160-NC 6P EMB SLAB 3068 NB -maker item #, 6 panel, embossed slab, 36" x 80", no brickmold?
?HIS NC S? 3068 MARY -left/right hand inswing, ?, size again and possibly inspector...this may be frame info?
?51/SM 24 -?
Others may have some more clues...but as I said..shouldn't be a problem getting what you need.
Where are you located? Stanley had a plant in NC before they were bought out by Masonite. They were probably the most common brand in the mid-atlantic region .
Old 05-07-09, 12:07 PM
D
I am in Mount Airy, Maryland.
The contractor was located in Frederick, Md. at the time - I don't remember the name of the company and they are not located where they were 10 years ago, if they are still in business. My wife says that the owner's last name was Eby.
I've done several Google searches, but with no success.
Thanks again.
Old 05-07-09, 12:16 PM
D
When I Google "210544 door" it comes up as Kwikset Grade 2 security entry knob locking door knob with Smart Key cylinder
Old 05-07-09, 12:50 PM
Gunguy45's Avatar
Super Moderator
Since you are in MD, it could one of several...Stanley, Masonite (almost identical), Peachtree, and a few more that escape me. I could tell by looking at the sweep, but I'm not ready for that long a roadtrip...lol
You'll find it..prob about $10.
EDIT Yeah, that number could be an internal factory number or something....
Oh, and if you haven't, and want to go to the trouble, you might check under the other leafs.
Old 05-07-09, 04:50 PM
D
The other leafs didn't have anything under them.
Old 05-08-09, 02:59 PM
GlobalLocky's Avatar
On the sliding door.....is there a window or glass panel? Sometimes the manufacturer name is on the metal frame that surrounds the glass. Usually printed or embossed in.
Old 05-08-09, 04:12 PM
D
No luck. It's a glass panel and I just looked (and felt) around the metal frame.
