Replacing French Door Window Grilles
Old 05-16-09, 06:49 PM
Does anyone know if French Door Replacement Grilles are available, and if so, where would be the best source for locating them. Just purchased a home with French Doors that have damaged grilles and would like to replace just the grilles. Have searched but have not been able to locate replacements. Appreciate any feedback on the topic.
Old 05-16-09, 08:41 PM
G
Your best bet is to find the name of the manufacturer of the doors if they are even still in business you should be able to get replacements directly from them.By the way you didnt mention what the "grills" are made of.If they are wood and need to be custom made I think you may want to look closely at different options.Take a picture and post it if you would like.I may have more input.
Beer 4U2
Old 05-17-09, 07:36 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Yep..all depends on how they are made. If they are steel doors, with raised plastic grilles secured with screws, you can order them almost anywhere that sells doors. Most of those are made by just a few companies that supply all the door manufacturers.
If they are wood, or plastic flush to the door, you really need the manufacturer.
