basement window
Old 05-22-09, 08:11 PM
F
basement window
Hi, I purchased a house about 4 years ago and one of the basement windows was removed, sealed and boarded up. Now the repair is showing some wear on both the inside and outside...At first I was just going to reseal it but now I think I'd prefer to add a new window. Is there anything I should be looking for other than measuring, framing and installing...I am quite handy and believe in doing a job right but have no expereince with this am worried about opeing a can of worms...any tips would be great!
Old 05-22-09, 08:30 PM
L
Received 1 Upvote on 1 Post
Is this window above grade, or below it?
If it's below, you'll need not only the window well but it'll also have to have proper drainage.
The window itself is not a big thing really. What kind of framing do you have to attach it to? (Concrete wall? Wood framing?) Make sure you get a window that fits the opening properly and get it sealed well.
Old 05-23-09, 01:22 PM
F
It is below grade and just has the cement wall for framing at the moment. It looks like they removed all the framing to seal it up.
Old 05-25-09, 07:08 PM
D
If you add a window make sure to measure it to 1/8 of an inch, not a quarter or a half. This means less caulking. The biggest issue here is water and insects. Make sure the window is sealed properly or this could be a disaster.
Old 05-26-09, 03:47 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Firstshack, like Mike said, being below grade, you may have to consider installing a window well and drainage system for it. It is possibly why it was removed in the first place.
Old 05-26-09, 08:31 PM
F
Yes, I will have to add a window well and the correct drainage...I'm aware of that, was more concerned about building the frame and measurements...thanks for the tips
Old 05-27-09, 04:31 AM
chandler's Avatar
I would frame it in 2x lumber, then either order or purchase a window for the size opening. The reason I say special order, you will have to stand on your head and tap your toes three times to get an ill fitting window in the opening. A special order will fit, may cost a little more, but it will fit. Then trim it normally after you seal and insulate it. We were concerned with water flow. It is your worst enemy, and sometimes DIY'ers put it off until it is too late, and the water damages their fine work.
