Cutting a big hole in lexan
Old 06-06-09, 08:32 PM
X
I need an easy way to cut a big hole in lexan. I have an a/c to pipe out my window. I tried many things over the years, and I've finally figured that lexan with the hose through it would probably would better than stuffing cardboard around the window kit and duct taping it.
My window is a swing open upward type, so I want to put lexan in the opening, with the a/c screw on connector for the hose glued on just for laziness, and let the hose pipe out that. How can I put a big enough hole for an a/c hose in the lexan without breaking it?
Old 06-06-09, 08:43 PM
nap's Avatar
nap
nap is offline
New Member
Received 2 Upvotes on 2 Posts
how large of a circle do you want?
Old 06-06-09, 09:42 PM
X
I need to get a hose through thats around 5 1/2 inches in diameter.
Old 06-07-09, 06:13 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
If its really lexan....you won't break it. If its plexiglass, I'd clamp a scrap of thin plywood to it then cut through both with a jig saw and a plastic blade. Some folks say misting the cut with water helps it to not melt back together.
Old 06-07-09, 07:16 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Or a 6" hole saw, through plywood and the plastic. Good clean cut.
Old 06-07-09, 04:17 PM
johnam's Avatar
Received 12 Upvotes on 11 Posts
Why aren't you using the window adapter kit that has the hole to connect the hose for venting of the hot air?
Old 06-07-09, 11:04 PM
X
the adapter kit is made for a slide down window. My window swings open, as I mentioned. So it needs to be the size of the window. They cater to the scared to stick the a/c in the window crowd vs the people who are using a portable because its the only option when they make the kit.
