filler for gaps between wood?
Old 06-13-09, 09:11 AM
F
I found some of the window frames have gaps between wood. when there is strong wind outside, I can fill air flow in. What is the easiest and best way to get them filled? I just want to fill it, I don't want to sand/repaint them.
Thanks.
Old 06-13-09, 05:15 PM
Received 758 Upvotes on 663 Posts
Generally caulking is used to fill gaps. What type of construction do you have? windows? siding?
Old 06-13-09, 05:49 PM
F
It is wood window frame. Is there a specific caulk for it? Thanks.
Old 06-13-09, 06:04 PM
If painted, use a good siliconized acrylic latex caulk. For stained wood you could use a clear latex caulk [goes on milky but dries clear] Apply the caulk as neat as you can and then wipe off the excess with a damp rag/sponge. You should push the caulk into the crack as you wipe.
It is best to stop the air on the exterior. What does the window frame look like on the outside?
Old 06-13-09, 06:43 PM
F
on the outside, the frame is covered by a layer of some material I don't know, it is not aluminum. I checked the outside frame and seems hard to find the gap.
I will try caulk inside to see if it is works.
Thanks.
Old 06-21-09, 12:29 PM
G
Sounds like the windows weren't insulated properly from the get go.
But using a decent (doesn't have to be great) latex caulking will allow you to fill and paint or not.
Cheers!
George
My window company:
NoAds.com
Old 06-21-09, 12:51 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Just an insertion. IMO it would be beneficial to remove the case molding on the inside and ensure there is insulation between the framing and window frame. If not, you can use the minimally expanding foam to fill this area. It should have been done when they were installed, but now's a good time to do it. Then replace your case molding, caulk and paint.
