Broken window latch
Old 07-30-09, 06:57 AM
R
Broken window latch
I have a Pella house window (probably 40 years old) which won't open. I can slide a putty knife around it except for the area behind the lock. I took out the screws on the lock and I think the spring which pushes the lock into the upper window is broken. The lock will not come off. How can I get this lock off to replace it?
Old 07-30-09, 06:02 PM
P
Temporarily Suspended
Start with a utility knife with a new blade. Try to cut through the top of the lock itself to expose the spring. If that doesn't work, try a gig saw.
Old 07-31-09, 09:48 AM
R
Thank you very much for your reply. I got out my tools to begin and discovered that I could take off the inner pane of the top window to make more room for sawing. This exposed the screws holding in the strike plate in the top window. Once I removed those the entire lock mechanism could be easily removed. I was correct that the latch was stuck locked into the strike plate. I had already talked to a local hardware store and the local Pella store who could not help me. Thank you for getting me on the right track!
Old 08-01-09, 05:32 AM
P
You're welcome, glad to hear all is well.
