Storm Door Problem
Old 08-23-09, 05:56 PM
P
Storm Door Problem
I am unable to get my storm door sliding window clean as I can't seem to figure out how to remove it, or alternatively, remove the screen in front of it. I have searched the door endlessly and cannot seem to figure it out... I have searched for similar threads and found none. I cannot find any brand, model, or other identifying info on the door. Any suggestions as to where I might find info on this? Or any ideas?
Thanks
Old 08-23-09, 06:31 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
You didn't state the make or model of door you have, so here goes a generic answer. Squeeze the window lifts inward and begin lifting the window. As you lift it, pull out on the lifts and the window will release from the bottom. Grasp the window securely and tilt it to a sideways angle until the tips release and the window comes out. Installation is the reverse of removal.
