Cracked wood frame door.
I screwed in a temporary wood block to prevent the door from opening.
I know its a stupid way.
Picture 082 on Flickr - Photo Sharing!
How would you guys fix this?
Thanks
Thanks
The best way to remove the frame is, of course, remove the door, remove the trim boards on both sides, inside and out, insert a reciprocating saw into the crack and cut the nails. The frame will practically fall out without damaging the surrounding area.
One more thing, the old door is made from masonite. At this time I cant afford a new door replace. Is there a way from the door being kicked and
screwdrivers?
