Rough Opening for New Door is Too Narrow
I'm trying to finish my basement before the family comes for Christmas and I have a couple of doors to install. Here is the problem:
My rough openings are (for some unknown reason) 29" and 29 1/2" wide.
First question: Can a 28" pre-hung door fit that RO?
Second question: If not, what should I do?
Rough Opening
You need at least 1/2 in. "wiggle room" in both width and height to install pre-hung doors. You need more extra space if the studs should happen to be out of plumb or not completely straight. Buy the door units and measure them carefully. I think you will need to redo the rough openings.
"First question: Can a 28" pre-hung door fit that RO?" --- Maybe, on one if perfectly plumb.
"Second question: If not, what should I do? " ----- If non-bearing, just pull one or both trimmers and replace with 1x4.
Be safe, Gary
Be safe, Gary
