How to trim window stool?
Old 03-26-10, 06:52 AM
G
I'm going to order replacement vinyl windows. My existing windows are only about 3" thick, while the replacements are 3.25", so I'll have to cut the trim back before I put it back on. That's not a problem, since it will be removed.
The window stool won't be removed. What's the best way of trimming about 1/4" from the inside of this, so the window fits?
I've been thinking of one of the vibrating tools - Dremmel makes one - that has a saw blade attachment. With that, I can cut neatly in place, I think. This will be slow, but I don't know any other tool that will let me cut it back easily.
Any other ideas?
Old 03-26-10, 03:57 PM
XSleeper's Avatar
Received 1,948 Upvotes on 1,748 Posts
Yes, the oscillating tools would work for that, but be advised you'll probably burn up a blade doing it... that's a lot of cutting.
I'd probably recommend the Rockwell or even a Harbor Freight over the Dremel. Just MHO.
If you aren't trying to match any other windows in the house, another easy thing to do is to put 1/2 x 3/4" baseshoe around your extension jambs and over the stool to hide any gaps (in case you have an ugly cut.)
