Using a dremel to cut a hinge mortice
Old 08-02-10, 10:19 AM
Is there a way to use a dremel to cut a hinge mortice? If so what bit/s would I use?
Thanks in advance!
Old 08-02-10, 10:41 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Yes...but you will need the router head adjustable depth accessory.... (ignore the bits)
Or the fancier more router-like versions...but the one in the pic will work. As to the bit....
A straight cut router bit (654 in the 2nd pic) will work...but for the cost of those you could get a reasonably good set of chisels and do the same job.
Old 08-02-10, 05:05 PM
Dremel bit question
Thanks so much. My husband did not do such a great job using the chisel, so I'm looking for something that is hopefully easier.
Old 08-02-10, 07:46 PM
Tolyn Ironhand's Avatar
Received 676 Upvotes on 573 Posts
If you have a router Porter Cable makes a pretty nifty jig to cut hinge mortises and IIRC it was not too much money. Got mine at the big orange store.
