Adding Interior French Doors?
Old 08-08-10, 07:21 PM
A
Question Adding Interior French Doors?
Our home office has a wide opening with no doors. I would like to add some French Doors to add a little privacy and sound barrier. The opening is 58 inches wide. How should I go about finding and adding these doors? Thanks!
Old 08-09-10, 11:02 AM
W
Received 60 Upvotes on 52 Posts
Opening
I am not seeing the opening to which you refer.
Locate the prehung door unit you want at a building materials supply store.
Verify the framed opening dimensions required for the unit.
Remove drywall to expose existing framing so you can tie in new framing.
Frame the opening. Install drywall. Install door unit, trim, and door hardware.
Old 08-09-10, 11:11 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
If the opening you mean is the one that is trimmed with the casing and rabited jambs, you might be in luck.
You didn't give a height measurement, but it's possible that when you remove trim and sheetrock you will have room for a 5' door. Otherwise you will need to frame the opening down using standard construction techniques and use a 4' door.
Old 08-09-10, 07:39 PM
A
The opening is visible on the left side of the picture. It has casing all the way around - just no door. I'm hoping I can fit a 60 inch door in there.
Old 08-10-10, 04:19 AM
Received 740 Upvotes on 646 Posts
Even if you remove the casing I doubt you'd have enough room for two 30" doors.
