pocket door
Old 12-09-00, 07:06 AM
Guest
I have a pocket door which has lost the hardware from the end inside the wall. It will still operate if gently coaxed, but i would like to repair it. How is this done?
thanx
Old 12-09-00, 07:18 AM
Mike Swearingen's Avatar
Cool
You will have to remove that section of the wall (pocket)to reinstall the hidden hanger.
Good Luck!
Old 12-09-00, 09:51 AM
A difficult job, and not much fun. Good Luck
Old 12-11-00, 03:05 AM
Guest
Wink pocket door
most pocket door installers screw the top trim to gain access to the track area. If not, take off the top trim to gain access. You may have to replace this. Remove the rollers that you can get to. You should now be able to swing that part of the door out of the opening enabling you to remove the entire door to repair or replace any parts that have come off or broke. I hope that I've been helpfull. Good luck.
