Milgard Window Glass Replacement
I have a single hung Milgard vinyl window I installed 2 years ago and the stationary glass is cracked. It is Argon filled, the pane(s) are 21" x 27" and all the quotes I have received to replace it are 3-4 times what I paid for the window. Is it feasible to replace it myself? If so is there somewhere to get directions?
Several pieces of siding outside cover the window, taking the window out is not a feasible option and I installed the windows myself, the warranty does not cover accidental breakage/cracking or self installation.
Milgard may still replace the glass, even if you installed them, just in case you haven't already called them. Stress cracks are pretty common even a few years after install.
