Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Garage door opener cold weather doesn't work well
Old 12-14-10, 06:28 AM
D
Whenever it's colder out I have to pull right up to the garage door before it will open with the remote. Sometimes it won't even do it then.
Works perfect in warmer weather (35 degrees+) . replacing batteries doesn't help. Any idea how to fix this or something I can buy to extend the range?
Old 12-14-10, 07:41 AM
W
Received 1 Upvote on 1 Post
What model GDO do you have? Is it a chain drive or screw drive? Does it work OK with the door disconnected?
Sometimes the door seal will freeze to the slab or the wrong lubricant on the drive mechanism will gum it up. .
Old 12-14-10, 07:57 AM
D
This is not a door issue. The range of the remote is severely effected by cold air for some reason. The door opens up fine, once I get close enough it's just whenever it's cold the range of the remote to the unit is terrible!
looking for options.
