Painting Steel Doors
We just had two new steel doors put in the front and back of our house, which are both painted with just a flat grey and seem to be a dirt magnet. I was wondering what would be the best type of paint to put on them, I don't mind the color but they are very hard to keep clean.
The back door has a window in it and I was also wondering if you can install a curtain rod in steel doors or is this a no no. Thank you in advance for your help. Pat
Hello
Sure you can paint them use a good meatal primer..first sand and prep the doors use a tack cloth and wipe them down,
prime sand a just a little and paint. curtain rod just drill a hole smaller than the screw where you want to install the hanger and use a sheet metal screw....
