How to fix stripped holes for door hinges.
Old 06-06-11, 08:46 PM
A few of my doors have the screws holes that hold the hinge onto the door totally stripped out. The hinge just barely hangs on. I tried filling the holes with wood putty but that didn't work to well. Is there a way to fill the holes with something and then redrill the holes for new screws?
skeeter
Old 06-07-11, 03:15 AM
Received 740 Upvotes on 646 Posts
Forcing tooth picks into the hole works well. If it's on the jamb side of the hinge - use a longer screw. I've heard you can glue a golf tee into the hole [sand smooth] and then redrill it for the screw.
Old 06-07-11, 03:42 AM
A
Hi,
I've inserted small plastic plugs like those used for in drywall for hanging pictures etc.
Hope this helps.
Old 06-07-11, 05:30 AM
Received 1,187 Upvotes on 1,145 Posts
Golf tees, wood dowels - depends on the size of the hole you have as to what is the best choice
Old 06-09-11, 11:30 AM
I think i'll try the dowels and epoxy them in. I believe it would be the strongest.
skeeter
Old 06-09-11, 12:26 PM
If you have epoxy, that's ok but regular wood glue is more than sufficient
