Framing In Existing Window
Stewart07's Avatar
KS
09-22-11, 10:09 AM   #1
I am redoing my bathroom and one of the three walls on the shower has a window. I was wanting to know how I should go about removing the window and framing it off so I can just make it a solid wall?
stickshift's Avatar
WI
09-22-11, 10:15 AM   #2
Welcome to the forums
What's on the outside? Drywalling up the inside or putting up a surround is the easy part, addressing the hole on the outside surface might be much more work.
Stewart07's Avatar
KS
09-22-11, 11:09 AM   #3
There is Vinyl siding on the outside I was afraid that might be an issue.
stickshift's Avatar
WI
09-22-11, 11:34 AM   #4
Removing a window is pretty easy, you just take off all of the trim and cut any nails. Repairing the hole on the inside isn't horrible, just some drywall, typically. On the outside, you'll need to put sheathing over the opening to match the rest of the house and you also hopefully have house wrap over that which would need to be addressed and then the siding after that.
You sure this window needs to go?
