header size for pocket doors
Old 10-16-11, 03:10 PM
B
how would you size a header for pocket doors?
Do I count the pocket where the door slides into as part of the opening?
Old 10-16-11, 03:23 PM
Yes, the header has to include the pocket portion of the doorway. I am assuming this is a load bearing wall??? If it it not, a large header is not needed.
Old 10-16-11, 07:30 PM
B
actually it's not a load bearing wall. so this 32" wide door may not actuallly need a 4x8 beam? only a 4x4 all the way across?
Old 10-16-11, 07:39 PM
XSleeper's Avatar
Received 1,961 Upvotes on 1,758 Posts
I would use a minimum of a double 2x6.
Old 10-16-11, 07:52 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Double 2x6. You don't want to introduce pressure treated lumber into the mix. It will warp, check and twist with you.
