Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Help! wet brick under window, old window sill, 1930's house
Old 10-20-11, 05:47 AM
W
Unhappy Help! wet brick under window, old window sill, 1930's house
Hey guys, I need some help. I just bought my first home, a 1930's rowhouse with old windows. The entire house is brick. Now when i was going through and patching up holes for painting, I noticed a mushy wall beneath one window. This window had duct tape all around it, which I figured they had done because of a draft or something. Well, the entire section below the window peeled off, and I discovered a moist windowsill (the part the joins the rough opening in the brick) and a wet wall. It was raining when I did this. There was drywall, cavity, and brick -- no insulation, which is probably the norm with an older home like this (?). What I need to figure out is whether it's leaking brick work, or a leaking window sill. What should I do to assess this problem? If the whole window needs replacement, I'm going to have to wait until I can afford it. I just don't know what I'd be able to do in the meantime to seal it up for the upcoming winter....
Old 10-20-11, 05:58 AM
Received 868 Upvotes on 759 Posts
Welcome to the forums!
You'll need to inspect the exterior side of the window. Caulking might be able to correct the moisture issue. Look for gaps around the perimeter of the window and for missing mortar.
