Rough Opening/ Door Size
Old 11-06-11, 09:40 AM
Hello-
I have a door way I wanted to put a door in.
The opening is 80” tall by 28 1/4” wide. Can you tell me what size door I would need?
Thanks for any help!
Old 11-06-11, 10:44 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums! A standard height door will not fit in that opening as it should be at least 81 1/2" in height. You can install a 2'2" or 26" door in that opening, but doubtful you will find it off the rack. Why was the opening made in such a fashion?
Old 11-06-11, 12:09 PM
W
Received 1 Upvote on 1 Post
Are your measurements the rough opening (no jamb) or a finished opening - as in an existing trimmed out doorway without a door? 80"X28 1/4" sounds like a standard finished opening for a 28" slab.
