Interior pre hung door jam issue
Old 02-20-12, 01:46 PM
R
I have purchased some prehung interior doors for my home. What I noticed is that three rooms door jam depth is 3 1/2 inches, while the pre hund doors are 4 9/16. My home is older, the existing frame has layer upon layers of paint. Is there a way i can shave down the frame of the pre hung door? Has anyone ever attempted this? What is my best option? The other rooms are fine they have 4 9/16. Suggestions are welcome.
Old 02-20-12, 02:06 PM
XSleeper's Avatar
Received 1,721 Upvotes on 1,545 Posts
Yes, you'd want to rip 1 1/4" off the side of the jamb that does NOT have the hinges on it. If you have a cordless skilsaw that has a rip guide, that would be your best bet to get a nice straight cut. You'd just have to be very careful to cut very straight at the end of your cut when the rip guide runs off the end of the door. Then you'd glue and brad nail some screen moulding (usually just under 1/4" thick x 3/4" wide) onto the cut edge of the jamb and sand it down until it's perfectly flush with the rest of the jamb.
Old 02-20-12, 03:36 PM
What he said. Many older homes had 2x3 walls on some rooms, so a standard door jamb won't fit. Trim it down as suggested.
Old 02-22-12, 06:02 AM
R
Thanks for the advice I will give it a try and let you know how I make out.
Old 02-22-12, 03:06 PM
Thanks for acknowledging our replies. Let us know what works.........we rarely hear if our advice works...............
