Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Do I put up the drywall first or install the window / door first?
Old 03-02-12, 12:06 PM
T
I am in the midst of a remodeling project. I plan on ripping out the drywall, sliding glass door, and window on my current project, but I don't know the order in which to do stuff after I remove the drywall. Which one should I install first? The sliding glass door and window or the new drywall?
Old 03-02-12, 12:25 PM
XSleeper's Avatar
Received 1,720 Upvotes on 1,544 Posts
If you need to resize the window or door openings, you would do them first. If you are sure they are the right size, then it really doesn't matter what order you do it in.
In some cases, it's nice to wait until all the drywall dust is gone before installing new doors and windows, or they can get awful dirty if you don't protect them with poly.
Received 742 Upvotes on 648 Posts
The door and window would get installed first - but not the interior trim. The trim goes on after the drywall is finished.
almost forgot welcome to the forums!
