Help, alumunum window screen has no tabs!
My second floor aluminum window screen TABS BROKE OFF. How do I remove it? Thank you. DeborahB
Just Bill, I was thinking the tabs she mentioned were the plastic or rubber tabs attached to the screen under the rubber that holds the screen in. You use them like handles to pull the screen toward the center to get it out from the channel to remove the screen. There I think is a spring metal piece on the opposite side to hold the screen in place if I am thinking correctly.
I believe you are thinking of the latch type screen like a storm door has. One either side to unlatch and move screen up.
Only the original poster will know for sure which they were speaking of.
