Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Cannot remove Weiser deadbolt from old front door
Old 05-07-12, 03:13 AM
Question Cannot remove Weiser deadbolt from old front door
Hello all. Thank you for taking the time to look at my issue and possibly provide any ideas.
Basically, I am having difficulty figuring out how to remove the deadbolt assembly from my large, thick front door. The apparent brand name is "Weiser." I have already removed any visible screws, and I have tried removing the assembly with the lock in both the lock and unlock positions. I've tried whacking it with a hammer, and I don't believe it is stuck due to paint. Do I need to perhaps remove the pin first?
Any ideas are most appreciated.
Here are some photos for reference, in case it helps:
Size:  18.5 KBName:  DSCF1061.jpg
Size:  18.0 KBName:  DSCF1062.jpg
Old 05-07-12, 03:29 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums! You'll probably need to remove the two allen head screws that are visible in pix #1.
Old 05-07-12, 07:56 AM
A-ha! I definitely overlooked the fact that those were allen head screws. That did the trick - it came right out!
Thank you so much for your help!!
