Need aluminum window replacement part
RickLagomarsino's Avatar
CAL
05-23-12, 11:57 AM   #1
Need the forums help. I have a single hung aluminum window. The plastic piece that is on the right side of the window which holds the string and clip on the top end and that hooks onto the bottom window to keep it up when we want to open it is broke and I need to replace it. Can anyone help? I've attached a picture of it. Any help or direction would be greatly appreciated.
chandler's Avatar
GA
05-24-12, 07:40 PM   #2
Welcome to the forums! Any idea as to the manufacturer of the window? If there is a gold sticker on the window somewhere, give us the numbers off it. Sometimes we can tell the brand and series from that.
CAL
05-26-12, 07:34 PM   #3
there's nothing that I can provide unfortunately. The sticker that was on there is faded to the point of being non-readable. Wish I could provide something for you.
Rick
XSleeper's Avatar
NE
05-29-12, 09:15 AM   #4
Can't help much without a brand or model, but you might contact some retailers online (like the search results here) and maybe they can help. It's hard to tell from your small picture what exactly is broken. We'd probably need a better description to help us understand what you are seeing- pictures of the broken part... next to pictures of a similar part that is NOT broken. There is also usually a part that attaches to the sash which holds the balance assembly in place that can break, allowing the balance assembly to just slide on past the sash without lifting it.
CAL
05-30-12, 05:55 PM   #5
Additional pictures
Here is another picture that might help out. The other one broke pretty much right in half.
CAL
05-30-12, 06:00 PM   #6
One more picture
Hopefully with these last two pictures it might help out some
chandler's Avatar
GA
05-30-12, 06:04 PM   #7
Trying to enlarge the original:
Attachment 826
What does this fun part do, exactly? Does it ride in a groove? Does it attach to springs? Does the window sash fit over it?
XSleeper's Avatar
NE
05-30-12, 06:29 PM   #8
I think I found it.
The part is part #62W-500 and can be found on page 35 of this PDF.
It can also be found on page 47 of this PDF.
