Rough opening depth is greater than depth of prehung door frames?
csanberg's Avatar
PA
06-08-12, 09:18 AM   #1
1956 ranch. Just starting to hang prehung doors. Depth of rough opening is about 5 1/4" (walls are composed of 3/8" drywall. 3/8" backer board, and plaster, adding approx. 1 3/4" to stud depth). Door frames are about 4 5/8" deep. So I am off by about 5/8". If I split this difference on each side, will standard casing be able to compensate for it? Or does anyone have a creative solution (simple and cheap)?
Thanks.
Gunguy45's Avatar
Super Moderator
AZ
06-08-12, 10:04 AM   #2
You need to extend the jamb somehow...no way around it. The hinges have to be far enough out for the door to open fully which will leave 5/8" that needs to be covered. Should be able to find some trim stock that could be attached.
The frame or extension needs to be flush with the wall for trim to work.
Vic
"I sometimes wonder how some people ever made it to adulthood..."
csanberg's Avatar
PA
06-08-12, 10:41 AM   #3
Thanks, Vic. That's what I figured, just wanted to make sure before I started looking for trim to extend the jambs.
Gunguy45's Avatar
Super Moderator
AZ
06-08-12, 11:18 AM   #4
Look for s4s or stop...that might get you what you need. Hope you have an air brad nailer?
Vic
csanberg's Avatar
PA
06-08-12, 12:39 PM   #5
Will do....and yes, I have several brad nailers, thank goodness.
