Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page > Jeld-wen double door inward opening - has lost weatherstrip under astragal
Old 07-17-12, 06:46 AM
I have not been happy with the quality of the this door selected by our builder, nor the installation. It is only three years old. This exterior double french door has an astragal with a molded piece of plastic or rubber under its base which is torn.
Since the weatherstrip piece is molded to the same shape as the astragal, does the entire astragal need to be replaced? If not, where do I turn for replacement? The manufacturer? Again, this is not the typical generic replacement molding.
Thoughts?
Old 07-17-12, 06:56 AM
Welcome to the forums
Some of the pros here may know this off the top of their head but just in case, can you post a couple pictures?
http://www.doityourself.com/forum/el...-pictures.html
Old 07-17-12, 09:08 AM
Pics are good idea. Here are two:Name:  010.jpg
Size:  36.1 KBName:  011.jpg
Old 07-17-12, 10:23 AM
XSleeper's Avatar
You'll have to make sure what part you need by removing and comparing it to anything you find online, but here are a couple parts for starters:
Astragal Boot, Bottom of double door, Left Hand - Black All About Doors and Windows, Parts and Hardware
Promax - Jeld-Wen - door - door replacement - door parts - door repair - promax
Not sure which you might have. You'd probably have to remove the hinge pins, and turn the door on it's side to have a good look.
Trackbacks are On
Pingbacks are On
Refbacks are On
