Framing Vinyl Windows
Old 10-07-12, 09:22 AM
I got a vinyl window that I to build a wood frame around it. I know I need wood and window caulking. I'll be hanging vinyl siding around the window. The window is going in a bathroom so cement board is gonna be used around on the inside of the wall. Is there anything else I should know or be aware of when doing this?
Old 10-07-12, 09:51 AM
chandler's Avatar
You'll need to extend your WRB (Tyvek) around the exterior of the frame and into the opening, install your window with a sealant under the flange, and wide window seal sticky tape around the perimeter of the window flange. First install a metal drip across the top to cover from the flange to the exterior of the molding, then start your sticky tape from the bottom working the two sides, then the top, overlapping the tape so water will drain off in a natural fashion.
As far as the inside, what is your contingency plan for water, assuming this is going in a shower area. Are you going to tile the sill and sides, and how waterproof is the window frame?
Old 10-07-12, 10:13 AM
Undecided on the inside but probably tile it. Yes going in the shower area above the bathtub.
Which window seal tape do I use? Lowes has several of them.
Old 10-07-12, 10:38 AM
chandler's Avatar
It's black, has paper and/or foil backing, is about 3 or 4" wide and stick in the summer Getting cooler, keep it in the house prior to using it. If you tile the window sill/sides, keep in mind the slight tilting of the sill tile so the water will drain back down, and use Redgard in the window opening around the corner to the wall, to help keep it moisture proof. If you are building in soad/shampoo cubbys (didn't think of that, did you?) use the Redgard in there also.
Old 10-07-12, 11:08 AM
No shampoo or soap cubbys. Lowes doesnt have red gard unless there calling it something else but ace hardware has it. Still looking that tape at lowes.com.
Old 10-07-12, 05:25 PM
chandler's Avatar
