door hinge for floor door questions
Old 10-29-12, 11:40 AM
I
Hi, I have a door (a piece of plywood with some hinges) in my porch that goes down into the basement and flush with the floor, currently you lift it up and it rests on the wall behind it. This is awkward and when I install wood floors it will become even more so. Rather than opening on the short side I want it to open on the long side with 2 or 3 hinges that will keep the door open without having to rest it on something.
This is pretty similar to what i'd want as it would allow me to hide hardware/hinges and keep the door as unobtrusive as possible. What kind of hardware is this? A hydraulic arm? Seems like a little arm for what looks to be a fairly heavy door?
Thanks for your help.
Old 10-29-12, 11:56 AM
I
Looks like I just need some gas cylinders and a recessed handle. Should be pretty straight forward.
Trapdoor to Basement - Basement Designs - Decorating Ideas - HGTV Rate My Space
Old 10-30-12, 03:58 AM
Received 742 Upvotes on 648 Posts
I'm sure you realize the gas strut is only to hold the door in the open position. It doesn't take the place of the hinges.
