Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
How Can I Replace the Locks on these Windows?
Old 12-06-12, 08:51 AM
U
Hello:
These windows are old but they are in pretty good condition. hey are double paned horizontal sliders. The problem is, I am missing two of the locks for these windows. I inquired with the manufacturer, MI, about replacement parts but I haven't heard back yet. The two generic pieces available at Home Depot that I tried did not fit. I would like the locks not so much for security, but for the fact that they create a tight seal between the windows and minimize a draft.
Do you have any ideas about how I can replace these lock pieces and/or otherwise deal the the security and draft issue? Thanks.
Old 12-06-12, 06:10 PM
P
Temporarily Suspended
Give the manufacturer a chance first. Are there any numbers on the locks?
Old 12-06-12, 07:22 PM
U
Hi. I looked on the lock and I do not see any numbers.
Old 12-06-12, 07:54 PM
P
Old 12-07-12, 04:18 AM
johnam's Avatar
Received 12 Upvotes on 11 Posts
This is a very common lock used on many older aluminum windows and simple to replace. You might be able to get them at local glass shop. Here are some styles: Hung and Sliding Replacement Sweep Locks and Keepers : SWISCO.com
Old 12-07-12, 07:11 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
I also like using these guys...http://www.aaascreen.com/catalog/6-PLP-Section-F.pdf
oops...that won't give you the contact info...AAA Screen.com
The catalog has all the measurements to compare to yours.
