Mounting interior door hinges left hand inswing
Wis99ski's Avatar
PA
12-07-12, 05:57 PM   #1
I am having a few issues mounting a left hand inswing door with hinges that are counter sunk. I need to turn the hinge upside down when mounting it on the right side of the door frame vs. the normal left hand side. The problem is that when you turn it upside down the hinge has a bushing at the bottom which matches the top of the pin - when it is upside down you then have to put the pin in from the bottom up which is not correct because it could potentially fall out. What am I missing here? The reason I cant turn the hinge upside down and flip it over is because the hinge is counter sunk and the screws would stick out if they were on the counter sunk side. Am I making sense here?
Types of door swings
How do you determine if a door is Right Handed (RH) or Left Handed (LH)? - Home Improvement
Ron53's Avatar
CAL
12-07-12, 06:00 PM   #2
That "bushing" can be removed and installed on the other end if need be.
Wis99ski's Avatar
PA
12-07-12, 06:49 PM   #3
Yes sorry for the wrong terminology here "bushing" but I tried hammering it out with a punch but it didnt seem to budge. Am I not hitting it hard enough?
Ron53's Avatar
CAL
12-07-12, 07:04 PM   #4
As far as I know they are press fit some are just tighter than others. I have had some that need a good coaxing.
Wis99ski's Avatar
PA
12-07-12, 07:29 PM   #5
problem solved. Door up with new oil rubbed bronze hinges and handles. Thanks guys.
