Metal Bi-Fold doors with new carpet
Old 01-08-13, 08:56 AM
Any help or advice would be great. We have four sets of metal bi-fold doors on the closets in our bedroom. We had new carpets installed and now there is no room for the doors to slide closed without rubbing on the carpet. The prior carpeting had no padding, we added it without considering the closet doors. There's not even enough room for an adjustment. It's tight, the doors rub on the carpet badly and my wife can't easily open/close them since they're metal and pretty heavy.
It will cost a lot more to replace the doors than to reframe the existing doors but then again, maybe it would be easier to install new wood bi-fold doors than reframe the existing metal doors. The moulding is something put in place by the old owners, it's pre-painted blue and no longer available anywhere so I'd have to match the paint and replace all the moulding around the doors too.
Would you replace the doors with new wooden bi-fold doors or just reframe the existing doors? Which is easier and is it even worth the cost to replace them? The doors were about $86.00 (x 4) when I priced them.
Old 01-08-13, 09:20 AM
Received 861 Upvotes on 753 Posts
Welcome to the forums Jim!
Could you post a few pics so we can better understand what you have - http://www.doityourself.com/forum/el...-pictures.html
Is the top door track mounted to drywall, or wood?
Old 01-08-13, 10:02 AM
They're top mounted to a wood frame. I'll post some pics tonight when I get home.
Old 01-08-13, 04:01 PM
XSleeper's Avatar
Received 1,948 Upvotes on 1,748 Posts
I'd probably go with wooden bifold doors, since you can cut the height down to any size you need. Also, if you're tired of the bifolds you could switch to bypass, or if you have the room and wanted to, you could install hinges and ball catches so that they pull open.
Old 01-08-13, 04:20 PM
P
Received 2,232 Upvotes on 1,991 Posts
Are you sure you are out of adjustment range on your existing doors. Usually the hinge pins screw in and out so you can adjust the door's height.
Old 01-08-13, 08:06 PM
XSleeper's Avatar
Bifolds often come in a set, with hinges, pivots and track. The last 4 door set I priced (for a 48" opening) was a cheap-o and it cost about $50, for all 4 pc, which were each about 11 3/4" wide. How wide is your finished opening?
