Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
My windows and the doors are cold through the frames.
Old 03-14-13, 10:10 AM
B
My windows and the doors are cold through the frames. I saw GREAT STUFF PRO 20 oz. Window & Door Insulating Foam Sealant
GREAT STUFF PRO 20 oz. Window & Door Insulating Foam Sealant-187273 at The Home Depot
Frost King E/O 3/4 in. x 10 ft. Rubber Foam Tape
Frost King E/O 3/8 in. x 17 ft. White Ribbed EPDM Cellular Rubber Weatherseal Tape-V23WA at The Home Depot
What do you suggest?
Thanks
Old 03-14-13, 10:14 AM
B
Received 47 Upvotes on 43 Posts
Are those frames wood or metal? The foam sealant you suggest is more for air sealing than insulation.
Bud
Old 03-14-13, 04:33 PM
B
Is the picture better?
Old 03-14-13, 04:49 PM
B
If I'm interpreting the picture correctly, those are aluminum frames. If so, then the foam around the perimeter will do little to help. I have suggested to some people, when cosmetics are not a concern, to build a complete covering, something that will cover the frames as well as the glass. The shrink plastic would help some, especially if you can space it away from the frame.
Bud
Old 03-14-13, 05:04 PM
Nashkat1's Avatar
Received 5 Upvotes on 4 Posts
Hey, if that looks good enough to use in the White house...
Old 03-15-13, 01:23 PM
B
What kind of Window Insulation Shrink Plastic Film Fit Inside Storm Windows do you use or suggest?
Thx
