Repairing 100+ y/o windows
Received 0 Votes
The house I recently purchased still has several old sash windows. Many are painted shut and those that aren't completely painted shut are at least painted enough that I cannot tell if they are double hung.
I plan on repairing all those windows this summer and am looking for advice.
I'll ignore reglazing at this time, I'm not sure it's needed.
1) Suggestions on what to use for stripping paint?
2) is "flat" spring bronze ok or should I splurge for "V"?
2a) Is the bronze for the lower sash supposed to go all the way up, or just half way so it seals when the window is closed?
3) Does anyone sell new three-track storm windows? I've found some where the upper glass is fixed, but I'd like three-track if my windows are actually double hung.
Any tips or advice that I'm not going to easily find online?
Thanks for any help. I'm sure I'll have more questions once I'm able to break the paint seals and investigate more.
I'm not sure what your definition of reglazing is but I'd address any missing or loose glazing while I was at it - it will never be easier/quicker than when you have the sash out!
Are you wanting to strip off all of the paint? or just get things working? With the age of the house the chances are high that they have a lead based paint on them. You'd want to make sure you contained and disposed of all the paint chips! Sanding of lead based paint can release the dust into the air where it can be inhaled
I have the triple track storm windows on my house. The ones I've replaced came from Lowes but it's been quite a few years.
Received 0 Votes
For the windows I need to do this work on, all glazing is intact and glass is fine. I have another window that I do need to replace some small panes on, but that's for another time. If my repairs start to show that I need to reglaze, I will certainly do it now as opposed to later.
I think that I want to strip off all the paint. I have no idea how many layers. I do understand that the age reflects the possibility of lead and would prefer to not sand. I'm more looking at chemical recommendations.
Lowes has the best storms that my limited searching has found, but I believe my windows are too large for any of their storms. Any decent guides out there on how to repair the storms that I do have? Many tracks need to be realigned and have more [whatever they use for weatherstripping] put in.
I don't do a lot of stripping but when a job comes up that requires it I normally talk to the paint rep at the store to get his take on which stripper will work best for the job at hand. I don't know how well they work on windows but I've heard that the peel away strippers are preferred when removing lead because it's easier to contain the debris.
You would need custom storm windows which are hard to find. I don't know where you are located in New York but I know of one manufacturer.
Karey Kassl Corporation - 180 Terminal Drive Plainview, NY 11803
Once you've got those, you can mount any storm window you want on the inside of the screen frame. If you need to rout or plane into the back of the screen frame to get your chosen storm to clear the sash, that's fine. Done right, it won't be visible from the outside and won't be noticeable from the inside.
I had fixed-glass units made to fit on the back of the screen windows I made for our old house. I had to take them out and store them every spring. In hindsight, I would have relieved the backs of the screen frames enough to install sliders with removable panels. That would have been nice to have in the spring and fall. Glass only, double track -- the screen is always in place.
Received 0 Votes
Thanks, Nashkat1. My main reason for wanting triple-track is so that I can lift screens up to go outside on the lower roof. But only two windows actually allow access and they have storms already (I just need to find a way to repair them).*
I've read very mixed reviews on Citristrip. Makes me wonder if it's only good for either newer or older paint. I'll look that the ToH article. I read a different one that mentioned a good product, but I cannot find that product anywhere around me.
I'll consider building out the windows instead of installing expensive bronze. Hopefully I have the skills and tools needed. Did you wind up using any weatherstripping anywhere?
* Were I to simply make full outside screens; how much of a downside would it be to simply get rid of the storms and build interior storms out of wood and plexiglass to be put up in the winter? The main downside I can come up with is condensation (which is pretty much good enough to not do it)(and after reading that article, I see that it is advised against for this very reason). I wonder if silica gel packets would be of any use.
One was that we enjoyed the look of the restored and refinished windows and their hardware so much that we didn't want to obscure that look in any way. The other reason, which was just as compelling, is that where we were, in Nashville, the weather in the Spring and Fall can vary significantly from week to week and day to day. I don't know how important that would be where you are, but we only got around to adding central air after we had lived there about ten years. The storm windows were only in place for three months, and being able to walk from window to window and adjust them to let air flow in and out was very important to us.
I've seen interior storm installed in a number of historic buildings since then. They can be both attractive and unobtrusive, but they're still there. Mostly, but not exclusively, these were museum houses that had no one living in them. In a home, I would want units that could be removed and set aside easily. That's why I don't really like the heat-shrink or other plastic film treatments either.
Condensation forms when you don't have an adequate thermal or air movement barrier, or both. We found that with well-fitted windows and our screen/storm units, that was not really a problem. One more reason I shy away from interior storm windows, BTW, is that I really don't want the condensation on the inside of the actual window. I'd much rather have it form on the inside of an exterior storm unit where it can't harm the interior finish.
As for the silica gel, sure, that might help. But it's a technological fix for a technological screw-up, IMO. Besides, I haven't seen it in 4 or 8 oz. packets.
I'll consider building out the windows instead of installing expensive bronze.Hopefully I have the skills and tools needed.
"As a beginner, start with sash from the barn or back room, where your early results will be good enough as you improve your technique. Once you have done 10 sashes, trying to do better each time, you’ll be more proficient. By the time you get around to the front windows, your glazing will look just fine."
Oh, yeah. Buy a package of canning paraffin at the grocery. Rub the outside edges and the face margins with a block of it. Rub it into each track, too. Do this each Spring and Fall and you should be able to enjoy the beauty and function of your windows for decades to come.
What do I know now that I wish I'd known when I started? Hmmmm.. Yes. Use sash chain to connect the pocket weights to the sash. I had to go back and do this after only about 5 years.
Received 0 Votes
Thank you so much.
It looks like I've already read that article on windows. I'll pore though it before I begin anything.
I'll give some thought to chains too. I'm still in a struggle with the fiance over whether our nonexistent money gets spent on new windows because she is convinced that it is necessary. It's interesting that people who cannot do repairs seem to think that new items (or expensive repairmen) are the only solution. As such, I want to do a window or two as simply as possible just to convince her (or at least make her begrudgingly say aloud) that repaired windows are fine and we don't need to spend thousands on replacements.
Received 0 Votes
I removed one lower sash last night. Easy enough, once I started cutting the paint away from the stop instead of cutting into the middle of the trim. With all that paint, it was hard to tell which corner was the meeting between trim and stop.
It looks like with will be a multi-week project where I fix it up a little, put it back together, and then start from the beginning and go further the next week. I think I lack the tools needed to really rebuild the windows at this time, but I can at least break the seal on everything and have them sort of functional for now. Then I'll track down pullies and see about getting weights made if I cannot find them in the windows themselves.
Here is a source for parts you may need. This company sells to the trade but I'm sure they will give you the name of a local dealer. When you get to the site, click on Window Replacement Hardware and then look at pages 114 to 115.
Strybuc Industries - Window and Door Replacement Hardware
Received 0 Votes
I took out another sash last night. The last "repair" included nailing very long brads all over the place. Just horrible. The sash is in such rough shape that I'm not sure I can really repair it at this time. I have very few power tools and, even if I had them, I have no place to put said tools.
For now, my job will just be to free all lower sashes and see about getting sash weights and chains. I spoke with a gentleman at a scrap yard to see if he had any weights. From the look on his face, you'd think that he had been collecting weights for the past 30 years and just melted down his entire stock last week. But he said he'd be on the lookout for weights as they come in.
The rest of my summer will be fixing/buying storm windows. Maybe I can get to rebuilding sashes this year, but I think I'll just wind up using rope caulk this winter and do the actual rebuilding next year when I can afford some proper tools.
Besides the jig saw, the only power tool I remember using is a corded drill. I used that, with a screw-shaped bit, to drill three holes through each inner stop, because i'd decided to mount those stops with brass screws and trim washers, for looks and to facilitate future access.
It's mostly a matter of patience and care, not high-tech tools, as I recall. Yes, your windows and mine were factory-built. But they were modeled on ones that had been site-built in earlier times.
Received 0 Votes
I've used a citrus based stripped around the house. I can't recall if it was Citristrip or another brand. I was just using it recently and I find it had a hard time getting the old oil based paint off. It works great with latex. It doesn't seem to go through too many layers either. I went and got one of Kleanstrips versions and had better luck. I'm sure there are much better ones available. Maybe not through the big box but a professional paint supplier.
You definitely don't want any lead dust floating through the air. Especially if you have little ones running around. Using a stripper will be the safest option to prevent lead contamination of the house.
Received 0 Votes
@drooplug
Thanks for confirming my guess on Citristrip's abilities. I'll check some of the smaller local paint stores for ideas.
I don't have any little ones, but I won't let that stop me from being safe-ish. I plan on putting plastic barriers around the windows when I strip and/or sand.
Received 0 Votes
Received 0 Votes
Fine. Safety it is.
But now I'm running out of reasons to get a 4" belt sander. I cannot just buy it for no reason at all. Guess I'll use that money to get some Trojan sawhorses. Or buy food and pay bills.
Fine. Safety it is.
Those Trojan sawhorses look really nice. The "sawhorses" I got were two pairs of sawhorse brackets. Still have them. I really like being able to cut all the way through a workpiece and, when needed, just make a new crosspiece for the horse.
At least two windows are so bad that they really need to be rebuilt or get a lot of rotted wood chiseled out and have new wood put in. I'm not sure I can make new wood the correct size without a planer/table saw.
I've never owned a planer or a table saw - I never had a good nough excuse.
Michael, I'm enjoying your approach to this, which sounds like keep at it but don't push too hard, enjoy the work, and learn as you go. And be sure to impress your fiance with your know-how!
Received 0 Votes
I'm guessing, since you read the article on repairing windows, you may have seen this one on How To Make a Dutchman Patch too.
Guess I'll put "router" at the top of the list. That's satisfying enough.
EDIT: Any suggestions for a router purchase?
#21
I would go to the Fine Homebuilding archives to see if they have reviews.
#22
Received 0 Votes
After doing very little work, I have three more windows that have functioning lower sashes. While this is much less than half of the total work I need to do, it certainly makes the windows about 90% as good as having both sashes work. Now I can get airflow how I want it...
Except for my bedroom. While the sash (the lower one, anyway. I haven't freed the upper) has the necessary channels and holes for sash chain/rope, the side jamb does not have an opening for a pulley. I'm thinking about getting an adjustable sash balance to take care of it. But I would welcome any input before I do so.
